Reading: Circuit Breaker Interview Questions & Answers
Inst Tools > Blog > Electrical Q & A > Circuit Breaker Interview Questions & Answers
Last updated: September 11, 2016 5:16 am
Electrical Q & A
3 Min Read
What is a Circuit Breaker?
Circuit Breaker is a mechanical device designed to close or open contact members, thus closing or opening an electrical circuit under the normal or abnormal conditions.
 How does a Circuit Breaker different from Switch?
Switch is just a device when can be able to open and close the circuit during normal operation. Whereas on the other hand circuit breaker has the ability to open and close the contacts during abnormal or fault conditions. Thus circuit breaker has the potential to break and make heavy short circuit currents. Auto-reclosures in the circuit beaker has the ability to re-close after certain designed duration to verify whether the short circuit was cleared.
What is meant by making capacity of the circuit breaker?
The making capacity of the circuit breaker when closed on a short circuit is the peak value of the maximum current wave (including dc component) in the first cycle of the current after the circuit is closed by the circuit breaker.
Why current chopping is not common in oil circuit breakers?
Current chopping is not common in oil circuit breakers because in most of the oil circuit breakers the arc extinguishing power is proportional to the magnitude of current to be interrupted.
Name the materials used for the contacts of vacuum circuit breakers?
Copper-Bismuth, Copper-lead, Copper-tellurium, Silver-bismuth, Silver-lead and Silver-tellurium are some of the alloys employed as contact materials in the vacuum circuit breakers.
Why current chopping considered as serious drawback in a circuit breaker?
The current chopping is considered as serious drawback because it sets up high voltage transient across the breaker contacts.
For EHV applications which type of circuit breaker is mostly preferred?
For Exta High Voltage (EHV) applications SF6 gas insulated switchgear is preferred.
What are the duties of Circuit Breakers?
Some of the duties of the circuit breakers are listed below:
  • Interruption of small inductive currents
  • Switching of unloaded transmission lines and unloaded cables
  • Switching of capacitor banks and reactors
  • Interruption of terminal faults
  • Interruption of short line faults
  • Asynchronous switching
Top 100 Switchgear and Protection Interview Questions
Power System Protection and Relays Questions & Answers
Transformers Questions & Answers Part-2
Induction Motor Protection Interview Questions Answers
Electrical Engineering Interview Questions
Questions & Answers of Power Systems
Power Systems Operation and Control Interview questions
Latest Electrical Motors Questions and Answers
Induction Motor Interview Questions & Answers
Basic Power Electronics Interview Questions
Electrical Drives and Controls Interview Questions
Power Electronics Interview Questions Part-1
Interview Questions on Transmission & Distribution
Single Phase Induction Motors Questions and Answers
Instrumentation Engineering Standards Interview Questions & Answers
Electrical Machines Objective Questions & Answers
Substation Interview Questions Answers
Battery Interview QuBattery Interview Question and Answersestion and Answers
DC machines and Induction Machines Viva Questions & Answers
Protection Relays Interview Questions & Answers
Electrical Machines Interview Questions and Answers
Electrical Switchgear & Protection Interview Questions
Guided-wave Radar Asset Management Parameters
Motor contactors
What is Contactor ?
Gas Detector Types
Sensor Technologies in Gas Detectors
AC generator Voltage Regulators
AC Generator Voltage Regulators
Differences Between AC and DC Motors
Generated EMF Quiz
Free Schneider PLC Training - Automation Course
Free Schneider PLC Training – Automation Course
Barometric gage with Magnetic Float
Process and Mechanical Parameters in Steam Turbine
