Reading: Tap Changing Switch Animation
Inst Tools > Blog > Electrical Animation > Tap Changing Switch Animation
Last updated: September 17, 2016 3:29 pm
1 Min Read
Animation of an on-load transformer tap changer, illustrating how taps can be selected without either interrupting supply or short-circuiting winding turns.
The tap changer starts at tap position 2, with load supplied directly via the right hand connection. Diverter resistor A is short-circuited, diverter B is unused.
Tap Changing Switch
If the tap changer is moved to tap 3, the following sequence occurs:
  1. Switch 3 closes, an off-load operation.
  2. Rotary switch turns, breaking one connection and passing load current through diverter resistor A.
  3. Rotary switch continues to turn, connecting between contacts A and B. Load now supplied via diverter resistors A and B, winding turns bridged via A and B.
  4. Rotary switch continues to turn, breaking contact with diverter A. Load now supplied via diverter B alone, winding turns no longer bridged.
  5. Rotary switch continues to turn, shorting diverter B. Load now supplied directly via left hand connection. Diverter A is unused.
  6. Switch 2 opens, an off-load operation.
Tap changing switch Animation
The animation then shows the tap changer returning to its starting position by reversing the above sequence of operations.
Electricity Magnetism
Electric Bell Working animation
Symmetric Three Phase Electric Current Flow Animation
Squirrel Cage Induction Motor Animation
How transformer works?
Current and Voltage Principle Animation
Three Phase Inverter Animation
Batteries in Series and Parallel Animation
Three Way Electrical Switch Working Animation
Electric Motor Working Animation
Asynchronous Motor Animation
Brushed DC Motor Working Animation
