Reading: Shunt Vs Series Capacitors Advantages
Inst Tools > Blog > Power Systems > Shunt Vs Series Capacitors Advantages
Last updated: September 21, 2016 10:39 am
Power Systems
2 Min Read
Capacitors aid in minimizing losses and helps in reducing operating expenses. Capacitors should be placed where the reactive power demand is more as capacitors generate reactive power and helps to maintain the voltage. Basically reactive power demand will be more at load side of the power system, hence capacitors should be placed as close as possible to load. In specific, capacitor banks should be placed where the low voltage problem occurs.Shunt capacitors are series capacitors are employed in power system for different purposes
  • Shunt capacitors and series capacitors in the power system generate the reactive power to improve the power factor and voltage, thereby enhancing the power system capacity and reducing the losses. In series capacitors reactive power generation is proportional to the square of the load current (I2Xc), whereas in shunt capacitors reactive power generation is proportional to the square of the voltage (V2/Xc).
  • The cost of installation of series capacitors is higher than that of the shunt capacitors. This is because the protective equipment for the series capacitors is often complicated. In addition to that, series capacitors are generally designed for higher power to cope up with the future increase in the load
  • For the same voltage improvement, the rating of the shunt capacitors will be higher than that of series capacitors. Series capacitors compensation may create certain disturbances: ferro-resonance in transformers, sub-synchronous resonance during motor starting, shunting of motors during normal operation and difficulty in protection of capacitors from system faults.
  • Series capacitors are more effective on distribution circuits with higher X/R ratio and for load variations involving a higher reactive content.
  • Series capacitors are generally employed to improve the stability of the system and shunt capacitors are generally employed to improve the power factor of the system
Some of the factors which influence the choice between the shunt and series capacitors are tabulated below:
Rotor Angle Stability of Synchronous Generators in Power System
Neutral Grounding Practice in Power System
Ungrounded or Isolated Neutral System Disadvantages
Harmonics effect on Induction Motor
Electrical Power System Protection Quiz
Advantages and Disadvantages of Per Unit System
  • F Dormani says:
    February 22, 2022 at 11:20 am
    1. The first “are” shall be “and” on your essay “Shunt capacitors are series capacitors are”
    2. The above table is confusing. Are you talking about transformer, lines , etc.?
Silicon Carbide Lightning Arresters Working Principle
Generating Station Grounding Principles
Current Limiting Reactors and Short Circuit Currents
Harmonics Disadvantages in Power System
Reactive Power Sources and Sinks in Power System
Why Symmetrical Components Used for Unbalanced faults in Power System
Advantages & Disadvantages of AC power and DC power
why-reactive-power-is-generated-at-load
Why Reactive Power is Generated at Load
Transformer Tap changer
Voltage Variations Effects on Power Plant Equipment
Underground Cable Fault Identification Methods
Auto Recloser Circuit Breaker in Power System
harmonics-effect-on-transformer
Harmonics effect on Transformer
Difference between Fixed Area and Variable Area FlowMeters
Difference between Fixed Area & Variable Area FlowMeters
Instrumentation Colleges in United States
Colleges to Study Instrumentation Engineering in United States
Electrical Ladder Diagram Control using Timers Example
Connect the Differential Pressure Gauge at the Filter
How Do You Connect the Differential Pressure Gauge at the Filter?
Serial Communication Interview Questions
Serial Communication Interview Questions and Answers
interface-level-measurement-need
Level Measurement Terminology
Ultrasonic Sensors Objective Questions
Falling Ball Viscometer Principle
