Reading: NEMA Enclosure Types Standards
Inst Tools > Blog > Standards > NEMA Enclosure Types Standards
Last updated: March 26, 2019 2:36 pm
Standards
It is more common to apply a NEMA (National Electrical Manufacturers Association) standard NEMA 250-1997 to the environment protection of equipment.
The standard is less systematic than IEC60529 but is neither the less useful as it deals with additional issues such as ice formation etc.
Type 1 – Indoor use to provide protection against falling dirt.
Type 2 – Indoor use to provide protection against falling dirt, and against dripping and light splashing of liquids.
Type 3 – Indoor or outdoor use to provide protection against falling dirt, rain, sleet, snow, and windblown dust; and that will be undamaged by the external formation of ice on the enclosure.
Type 3R – Indoor or outdoor use to provide protection against falling dirt, rain, sleet, and snow; and that will be undamaged by the external formation of ice on the enclosure.
Type 3S – Outdoor use to provide protection against falling dirt, rain, sleet, snow, and windblown dust; and in which the external mechanism(s) remain operable when ice laden.
Type 4 – Outdoor use to provide protection to personnel against falling dirt, rain, sleet, snow, windblown dust, splashing water, and hose-directed water; and that will be undamaged by the external formation of ice on the enclosure.
Type 4X – Outdoor use to provide protection against falling dirt, rain, sleet, snow, windblown dust, splashing water, hose-directed water, and corrosion; and that will be undamaged by the external formation of ice on the enclosure.
Type 5 – Indoor use to provide protection against falling dirt; against settling airborne dust, lint, fibers, and flyings; and to provide protection against dripping and light splashing of liquids.
Type 6 – Outdoor use to provide a degree of protection against falling dirt; against hose-directed water and the entry of water during occasional temporary submersion at a limited depth; and that will be undamaged by the external formation of ice on the enclosure.
Type 6P – Outdoor use to provide protection against falling dirt; against hose-directed water and the entry of water during prolonged submersion at a limited depth; and that will be undamaged by the external formation of ice on the enclosure.
Type 12 – Indoor use to provide protection against falling dirt; against circulating dust, lint, fibers, and flyings; and against dripping and light splashing of liquids.
Type 12K – Same as Type 12 with knockouts.
Type 13 – Indoor use to provide protection against falling dirt; against circulating dust, lint, fibers, and flyings; and against the spraying, splashing, and seepage of water, oil, and non-corrosive coolants.
The above Type classifications also imply a protection to personnel from dangerous voltages (up to 1000V), and that outdoor rated enclosures can also be used indoors.
The following table provides a conversion from NEMA to IP although not in the reverse direction as the NEMA protection level is matched against an equal or higher IP level.
NEMA Standard Codes
NEMA to IP Ratings
NEMA Enclosure Ratings
Analytical Standards
What is IEC 61508 ?
Difference between Explosion Proof and Intrinsically Safe
Zone vs Class / Division
Pressure Standards
Purge & Pressurization Systems Interview Questions
Pre-Startup Safety Review (PSSR)
Why is IEC 60269 Important? – Electrical Applications
IP Ratings and Equivalent NEMA Ratings
Identification of Equipment
Comparison of IEC & NEC Area Classifications
device-specific-diagnostics-to-ne107-status-signals
NAMUR NE107 Standard
Instrumentation Cables Testing Standards
Ingress Protection Standard
Ingress Protection Rating
HAZOP
What is HAZOP ?
Valve Standards
List of Valve Standards
NFPA Standards (National Fire Protection Association Standards)
UL 489 Circuit Breaker
Difference Between UL489 and UL1077
Typical Purging Installation
Purging of Instruments
Temperature Transmitter with Thermocouple
Thermocouple Extension and Compensating Cables
Construction of strain gauge Load cell
Strain Gauge Load Cell
Advantages & Disadvantages of CNC Milling
What are the Advantages & Disadvantages of CNC Milling?
Carbon Monoxide Gas Detector
Carbon Monoxide Gas Sensor Principle
Three Wire RTD Temperature Compensation
Ambient Temperature Effects on RTD
Problem in Water Level Control System
Reasons to Calibrate Flowmeters
Reasons to Calibrate Different Types of Flow Meters
