Reading: IP Ratings and Equivalent NEMA Ratings
Inst Tools > Blog > Standards > IP Ratings and Equivalent NEMA Ratings
Last updated: February 18, 2017 9:50 am
Standards
2 Min Read
IP Ratings (Ingress Protection) and Equivalent NEMA Ratings Explained
IP Ratings
An IP rating contains two numbers (i.e. IP65) in most instances which relate to the level of protection provided by an enclosure or housing.
The first number relates to protection from solids as follows:
0:  No Special Protection1:  Protected against solid objects up to 50 mm in diameter2:  Protected against solid objects up to 12 mm in diameter3:  Protected against solid objects up to 2.5 mm in diameter4:  Protected against solid objects up to 1 mm in diameter
5:  Dust protected
6:  Dust tight
The second number relates to protection from liquids as follows:
0:  No special protection1:  Protected against dripping water2:  Protected against dripping water when tilted up to 15º from normal position3:  Protected against spraying water4:  Protected against splashing water
5:  Protected against water jet spray
6:  Protected against heavy water jet spray
7:  Protected against the effects of immersion
8:  Protected against submersion
Example:  IP66 = Dust tight and protected against heavy water jet spray.
NEMA (National Electrical Manufacturers Association) ratings can be approximately compared to those of the IP system as shown below.  Other factors such as corrosion protection are also involved in the NEMA system, please refer to official documentation for detailed information. Below find the equivalent codes.
NEMA 1:    IP10
NEMA 2:    IP11
NEMA 3:    IP54
NEMA 4:    IP56
NEMA 4X:  IP66
NEMA 6:    IP67
NEMA 12:  IP52
NEMA 13:  IP54
Difference between Intrinsically Safe and Flameproof Equipment ?
Hazardous Area Classification Questions
ISA codes for Process Instrumentation
Instrumentation Standards
Ingress Protection Rating
Difference Between UL489 and UL1077
Hazardous Area Terminology
Purging of Instruments
Hazardous Area Classification markings
NFPA Standards (National Fire Protection Association Standards)
ATEX Standards
Instrumentation Cables Testing Standards
IEC Area Classification System
Instrumentation Engineering Standards Questions & Answers
ATEX Certification Codes
Understanding Hazardous Area Classification
Electronic Equipment Purging Principles & Standards
Hazardous Area Classification Comparison
Comparison of IEC & NEC Area Classifications
Zone vs Class - Division
Zone vs Class / Division
NAMUR NE 43
What is NAMUR NE 43?
Manchester encoding
Foundation Fieldbus Electrical Parameters
Ratio Control Example
Ratio Controller Example
electrical-drives-questions-answers
Electrical Drives Questions & Answers
Chlorine Cylinders
Chlorine Gas Hazards
What is ELCB
What is ELCB? Principle, Advantages, Disadvantages, Applications
Oscillating Piston Flow Meters Principle Animation
How to Select a Flow Meter
Traffic Lights Ladder Diagram using Timers
