Reading: How transformer works?
Inst Tools > Blog > Electrical Animation > How transformer works?
Last updated: November 9, 2017 3:39 pm
2 Min Read
A transformer is based on the fact that when an AC current flows through a wire, it generates a magnetic field commonly known as a “magnetic flux” all around it. The strength of this magnetic field is directly related to the size of the electric current and is known as the magnetic flux density. So the bigger the current the greater the magnetic flux density.
Now if another wire comes close to a wire with an AC current flowing through it , it to will experience an electric current flowing through it.
So if we put a second coil of wire next to the first one, and send a fluctuating electric current into the first coil, we will create an electric current and voltage in the second wire.
The current in the first coil is usually called the primary current and the current in the second wire is known as the secondary current.
Generation of Flux in Transformer coil
In actual fact what happens is an electric current is passed through empty space from one coil, the primary coil, of wire to another, the secondary coil. This is called electromagnetic induction because the current in the first coil induces a current in the second coil.
Three Phase Inverter Animation
Electric Motor Working Animation
Three Way Electrical Switch Working Animation
Tap Changing Switch Animation
Batteries in Series and Parallel Animation
Squirrel Cage Induction Motor Animation
  • Martins Green says:
    November 10, 2017 at 6:34 am
    i enjoyed the site more than any site in engineering i have come across especially details in instrumentation. I need more on Sensors
Asynchronous Motor Animation
Brushed DC Motor Working Animation
Symmetric Three Phase Electric Current Flow Animation
Electricity Magnetism
Electric Bell Working animation
Current and Voltage Principle Animation
