Reading: Generating Station Grounding Principles
Inst Tools > Blog > Power Systems > Generating Station Grounding Principles
Last updated: September 21, 2016 10:35 am
Power Systems
2 Min Read
Grounding systems in the generating stations should able to meet the following grounding principles:
Grounding Principles:
  • Metallic enclosure on electrical equipment and exposed non current carrying conductive materials in generating station which are capable of being energized due to insulation failure or accidental contact of the energized conductors shall be grounded
  • The grounding should limit the step and touch voltage to acceptable limits during a ground fault on the enclosed equipment.
  • The grounding in generating station should provide ground fault current return path so that ground faults can be detected by protective devices and can able to isolate the faults or can provide an alarm to the operator
  • The grounding conductors and connections should withstand the ground fault current for the duration of the fault, without being damaged by thermal, thermo-mechanical or electromechanical stresses.
  • The grounding conductors should be continuous; no switching device should be inserted in the grounding conductors (except where the operation of the switching device will also automatically disconnect all power sources to the equipment grounded by that conductor). Structural changes after installation should not interrupt the grounding conductor. In general, equipment enclosures should not be used as part of the grounding conductor.
  • Ground conductors should able to withstand any applied mechanical stresses and should be reliable.Ground connections which are exposed should be accessible for inspection
  • Grounding system in generating station should be designed in such a way to minimize the corrosion to adjacent structures and enclosures
Neutral Grounding Practice in Power System
Why Symmetrical Components Used for Unbalanced faults in Power System
Underground Cable Fault Identification Methods
Reactive Power Sources and Sinks in Power System
Why Reactive Power is Generated at Load
Harmonics effect on Transformer
Advantages & Disadvantages of AC power and DC power
Silicon Carbide Lightning Arresters Working Principle
Electrical Power System Protection Quiz
Voltage Variations Effects on Power Plant Equipment
Rotor Angle Stability of Synchronous Generators in Power System
Auto Recloser Circuit Breaker in Power System
current-limiting-reactors-and-short-circuit-currents
Current Limiting Reactors and Short Circuit Currents
harmonics-disadvantages-in-power-system
Harmonics Disadvantages in Power System
Transformer Tap changer
Advantages and Disadvantages of Per Unit System
shunt-capacitor-advantages-in-power-system
Shunt Capacitor Advantages in Power System
Shunt Vs Series Capacitors Advantages
harmonics-effect-on-induction-motor
Harmonics effect on Induction Motor
SMART Control Valve Positioner
Electronic Valve positioners
Single Block and Bleed Valve Manifold
Single Block and Bleed Valve Manifold Operation
Fence grounding specifications
All About Electric Fence Gates
Process Control & Instrumentation Objective Questions – Set 4
NH3 Storage Tanks Ammonia Gas
NH3 Storage Tanks Ammonia Gas Venting Issue – Root Cause Analysis
Synchronous Machine Quiz
Vehicle Electrical Batteries upgrade
Upgrading the Electrical System in an Automobile
