Reading: Advantages of Suspension Insulators and Pin type Insulators
Inst Tools > Blog > Transmission & Distribution > Advantages of Suspension Insulators and Pin type Insulators
Last updated: September 19, 2016 2:40 am
2 Min Read
With increase in the operating voltage the insulation requirement will also increases. Transmission system will have transmission voltages as high as 400kV and above voltage levels. At these voltages the pin insulators become bulky, cumbersome and costly.  Some of the advantages of suspension insulators over pin type insulators are explained below:
Advantages of suspension insulators:
  • Suspension insulators are cheaper  in cost compared to pin type insulators for operating voltage above 50kV
  • Each unit of suspension insulators (insulator disc) is designed for comparatively low voltage (11kV) and can be increase the insulation strength by connecting these insulator disc modules in series. The number of insulator discs require depends on the operating voltage
  • Suspension type insulators give more flexibility to the line and mechanical stresses due to wind and other factors are reduced in this suspension type insulator arrangement. The connection at the cross arm is such a way that the insulator string is free to swing in any direction and thus takes up a position where it experiences only a pure tensile stress
  • The suspension type insulators when used in conjunction with steel supporting structure has the advantage of rendering the conductor less liable to the affected by cross-arm thus enabling the tower to function as lightning rod
  • In case of rapid increase in the load on the transmission line the increase demand can be met by raising the line voltage than to provide another set of conductors. With suspension type insulators additional line insulation requirement can be obtained by simply adding one or more discs to the string
  • In case of long spans (river or valley crossings) where heavy conductor load is to be sustained, two disc insulators can be yoked. Such an arrangement is not possible in pin type insulators
  • The only disadvantage of suspension type insulators is that large spacing between the conductors are required than with the pin type insulators due to large amplitude of the swing of the conductors.
Advantages & Disadvantages of AC and DC Power Transmission
Single Phase Earth Return System Advantages & Disadvantages
Surge Impedance Loading of Transmission Line
Insulating Material for Cable Requirements
Electrical Power Distribution
Conductor Size Selection in Distribution Power System
Current Limiting Reactors in Power System
Electrical Power Transmission And Distribution
Comparison of HVDC transmission and HVAC transmission
Advantages of HVDC transmission
Charging Currents in Transmission Lines
Classification of Transmission Lines
Advantages of Bundled Conductors in Transmission Lines
Electrical Contactor, Switch, Circuit Breaker
Difference between Solid Conductor and Stranded Conductor
Captive Power Plant Trip Root Cause Analysis
Difference between Single-phase and three-phase power supply
Difference between Single-phase and Three-phase Power
Single-Phase Full Wave AC-DC Converter Quiz
Reading Clock data in PLC
Real-Time Clock in Omron PLC? – CX Programmer
Transistor Emitter Feedback Bias
Boolean Logic Operations Objective Questions
Turbine to Gearbox Alignment Drifts Caused Pump Transfers Problems
RCA Related to Trip Throttle Valve (TTV)
MOS Digital Integrated Circuits Objective Questions
