Reading: Advantages and Disadvantages of Per Unit System
Inst Tools > Blog > Power Systems > Advantages and Disadvantages of Per Unit System
Last updated: September 19, 2016 4:49 am
Power Systems
2 Min Read
In power system analysis, per unit (pu) system is used to express a physical variable as a fraction of base or reference value. Per Unit (pu) is commonly used for the calculation of voltage, current , impedance, and power in power flow and related calculations.
per unit (pu) system advantages:
  • Circuits are simplified
  • Voltages have same range in per unit in all parts of the system from EHV system to distribution and utilization
  • When expressed in the per unit system, apparatus parameters usually fall in narrow range regardless of apparatus size. For example, generator reactances in per unit are similar for both 100 MVA machines and 1000MVA machines. This facilitates data checking and hand calculations.
  • For circuits connected by the transformers, per unit system is particularly suitable. By choosing suitable base kV for the circuits the per unit reactance remains the same, referred to either side of the transformer. Therefore the various circuits can be connected in the reactance diagram.
  • This method is ideal for eliminate ideal transformers as circuit components since the typical power system contains hundreds, if not thousands of transformers and this is non trivial saving
  • Sqrt (3) factor in the three phase circuit calculations is eliminated
per unit (pu) system disadvantages:
  • For transmission lines, its value of impedance and admittances in physical units (eg: ohms/km) that are of same magnitude regardless of voltage level or MVA rating
  • Equivalent circuits of the components are modified, making them somewhat more abstract.Sometimes phase shifts that are clearly presented in the unscaled circuits varnish in per-unit system
Reactive Power Sources and Sinks in Power System
Ungrounded or Isolated Neutral System Disadvantages
Electrical Power System Protection Quiz
Harmonics effect on Transformer
Why Reactive Power is Generated at Load
Harmonics Disadvantages in Power System
Underground Cable Fault Identification Methods
Rotor Angle Stability of Synchronous Generators in Power System
Neutral Grounding Practice in Power System
Harmonics effect on Induction Motor
Current Limiting Reactors and Short Circuit Currents
Auto Recloser Circuit Breaker in Power System
Silicon Carbide Lightning Arresters Working Principle
Shunt Vs Series Capacitors Advantages
Why Grounding
Generating Station Grounding Principles
why-symmetrical-components-used
Why Symmetrical Components Used for Unbalanced faults in Power System
Transformer Tap changer
Voltage Variations Effects on Power Plant Equipment
shunt-capacitor-advantages-in-power-system
Shunt Capacitor Advantages in Power System
Advantages & Disadvantages of AC power and DC power
Ion Analyzers Questions and Answers
Ion Selective Electrodes Questions and Answers
What is Pump Redundancy
What is Pump Redundancy?
Double Block and Bleed Valves Opening or Closing Sequence
Air Cylinder Consumption Calculation for Control Valves
Measurement Unit Conversions
Extended Timer Logic in PLC
Internet of Things Communication Models (IoT)
