Reading: Advantages & Disadvantages of AC power and DC power
Inst Tools > Blog > Power Systems > Advantages & Disadvantages of AC power and DC power
Last updated: September 19, 2016 4:54 am
Power Systems
2 Min Read
First electric power system was build in New York city in 1882. DC power was generated by steam generator supplying power to 59 consumers. During the decade many small power systems were developed throughout the  world using dc power.
In spite of initial wide spread of dc power they have certain limitations that dc power should be generated and delivered to short distances, for long distance transmission I2R losses and voltage drops in the lines were not acceptable for generation of the dc power. Hence a need has come to transform the voltage levels became necessary.
With the development of transformer and ac transmission pave an important path to generate electrical power. Then a controversy has come over whether the electrical utility industry should be standardized with ac power or dc power.
AC power has won over the DC power due to some advantages
  • In ac power voltage levels can be transformed, thus electrical power can be generated at low voltage and step up for transmission for long distances to reduce I2R losses and can be step down at distribution end.
  • AC generators are much simpler than DC generators.
  • AC motors are much cheaper and simple in construction compared to DC motors. (Induction motors are simple and rugged in construction and requires less maintenance than dc motors)
Due to the above reasons ac power out rule the dc power for generation, transmission and distribution.
Disadvantage of ac power:
However it should be remembered that ac power has some disadvantages such as
  • Interference with the neighboring communication lines
  • Harmonics in the power system
  • Losses such as Skin effect and corona loss
Advantages and Disadvantages of Per Unit System
Voltage Variations Effects on Power Plant Equipment
Why Reactive Power is Generated at Load
Generating Station Grounding Principles
Silicon Carbide Lightning Arresters Working Principle
Harmonics Disadvantages in Power System
Electrical Power System Protection Quiz
Rotor Angle Stability of Synchronous Generators in Power System
Reactive Power Sources and Sinks in Power System
Underground Cable Fault Identification Methods
Neutral Grounding Practice in Power System
Shunt Capacitor Advantages in Power System
Auto Recloser Circuit Breaker in Power System
harmonics-effect-on-transformer
Harmonics effect on Transformer
Shunt Vs Series Capacitors Advantages
why-symmetrical-components-used
Why Symmetrical Components Used for Unbalanced faults in Power System
ungrounded-or-isolated-neutral-system-disadvantages
Ungrounded or Isolated Neutral System Disadvantages
current-limiting-reactors-and-short-circuit-currents
Current Limiting Reactors and Short Circuit Currents
Transformer Tap changer
Cold Email Deliverability
Cold Email Deliverability – Latest Comprehensive Guide
Modbus in Industrial Networks
Why are Impulse Lines often Installed in a Sloping Manner (Angle)
Why are Impulse Lines often Installed in a Sloping Manner?
Parallel Circuit Parallel Current Calculations
Parallel Circuit Current Calculations
Multimeter Digits
Multimeter – What Do Digits and Counts Mean?
Electrical Machines MCQ Series 9
Comparison of Pressure Instruments - Industrial Instrumentation
Comparison of Pressure Instruments – Industrial Instrumentation
NEMA to IP Ratings
NEMA Enclosure Types Standards
