Reading: Advantages of Bundled Conductors in Transmission Lines
Inst Tools > Blog > Transmission & Distribution > Advantages of Bundled Conductors in Transmission Lines
Last updated: September 19, 2016 2:18 am
2 Min Read
For transmission of more power for long distances to load centers Extra High Voltage (EHV) transmission is employed. Implementing Extra High Voltage has advantage of reduction in the copper losses and improves efficiency.
However transmission of voltage beyond 300kV will poses some problems such as Corona effect which causes significant power loss and interference with communication circuits if round single conductor per phase is used. In order to reduce corona effect hollow round conductors are used. Keeping economical constraints other option is instead of using hallow round conductor it is preferable to use more than one conductor per phase which is called Bundled Conductors. For transmission of power beyond 400kV bundled conductors are employed.
Advantages of Bundled Conductors:
Bundled conductors are primarily employed to reduce the corona loss and radio interference. However they have several advantages:
  • Bundled conductors per phase reduces the voltage gradient in the vicinity of the line. Thus reduces the possibility of the corona discharge. (Corona effect will be observed when the air medium present between the phases charged up and start to ionize and acts as a conducting medium. This is avoided by employing bundled conductors)
  • Improvement in the transmission efficiency as loss due to corona effect is countered.
  • Bundled conductor lines will have higher capacitance to neutral in comparison with single lines. Thus they will have higher charging currents which helps in improving the power factor.
  • Bundled conductor lines will have higher capacitance and lower inductance than ordinary lines they will have higher Surge Impedance Loading  (Z=(L/C)1/2). Higher Surge Impedance Loading (SIL) will have higher maximum power transfer ability.
  • With increase in self GMD or GMR inductance per phase will be reduced compared to single conductor line. This results in lesser reactance per phase compared to ordinary single line. Hence lesser loss due to reactance drop.
Difference between Solid Conductor and Stranded Conductor
Electrical Power Transmission And Distribution
Charging Currents in Transmission Lines
Advantages & Disadvantages of AC and DC Power Transmission
Advantages of HVDC transmission
Single Phase Earth Return System Advantages & Disadvantages
Classification of Transmission Lines
Current Limiting Reactors in Power System
Surge Impedance Loading of Transmission Line
Electrical Power Distribution
Conductor Size Selection in Distribution Power System
Comparison of HVDC transmission and HVAC transmission
Insulating Material for Cable Requirements
advantages-of-suspension-insulators-and-pin-type-insulators
Advantages of Suspension Insulators and Pin type Insulators
C-Type Bourdon Tube
Types of Bourdon Tube
Boolean Logic Operations Objective Questions
Download Electrical Enclosure Book
If Else Statement in SCL Language
Thyristor Family Objective Questions and Answers
Earth Meter Working Principle
How Earth Resistance is Measured
Arc Fault Breaker (AFB) Electrical Problem Solved
Premature Arc Fault Breaker Failures
Redundant system communication cable
What is Interface Module in Siemens PLC?
