Reading: Sulfur Hexafluoride Gas (SF6) Properties
Inst Tools > Blog > Switchgear & Protection > Sulfur Hexafluoride Gas (SF6) Properties
Last updated: September 19, 2016 1:59 am
1 Min Read
  • Heavy, chemically inert, non toxic
  • No poisonous effect on the human body but decomposition products are poisonous
  • Color less and odor less
  • It is gaseous at normal room temperature and pressure
  • Density is about 6.6g/l at 20oC (5 times denser than air)
  • Critical temperature is at 45.6oC and can be liquefied by compression
  • Very good insulant with high dielectric strength
  • SF6 gas is electo-negitive ( tends to attract the free electrons and has the arc quenching property). Because of this main reason SF6 gas is used for arc quenching and insulation medium in circuit breakers.
  • The gas is highly stable
  • Unlike solid insulation materials, electrical breakdown of sf6 gas does not result in permanent deterioration of its properties.
  • Decomposition occurs on the exposure to the electric arc. (Disassociation products will be SF2 and SF4 lower order fluorides)
Advantages & Disadvantages Electromagnetic Relays
Substation Safety Clearances
Creepage Distance for Insulators in Substation
Functions of Instrument Transformers (CTs and PTs)
Advantages & Disadvantages of Oil Circuit Breakers
Advantages and Disadvantages of Air Blast Circuit Breakers
  • Mani says:
    July 6, 2022 at 7:43 pm
    – Density is about 6.6g/l at 20oC (5 times denser than air)
    Clarification: please verify the density of SF6 in circuit breaker, should be in 6.6 Kg.. if i am not wrong.
Methods to Reduce Step Potential and Touch Potential in Substation
What Is Step and Touch Potential and Reducing Resistance To Ground?
