Reading: Substation Safety Clearances
Inst Tools > Blog > Switchgear & Protection > Substation Safety Clearances
Last updated: September 19, 2016 2:13 am
2 Min Read
Majority of electrical substations will be air insulated type. All the electrical equipment live parts will be  exposed .All the electrical equipment in the substation shall be arranged in such a manner to ensure the clearance space between the live parts and other equipment of the substation (grounded or ungrounded). Adequate clearances should be provided for safety of the operating and maintenance personnel and also to prevent any conducting path between the phases.
Safety clearances associated with different voltage levels are given in the table below.
  • Phase to phase clearance is the minimum clearance required to be provided between the live parts of different phases or is the minimum clearance between the same phases
  • Phase to earth clearance is the minimum clearance required to be provided between the live parts of the system and earth structures
  • Sectional clearance is the distance between the live parts of the phases and the terminals of the work section. This limits of work section or maintenance section may be a platform or ground on which operation personnel can carryout his task safely
·  Ground clearance is the vertical clearance between the live parts of the equipment and the earth surface
Sulfur Hexafluoride Gas (SF6) Properties
Advantages & Disadvantages Electromagnetic Relays
Methods to Reduce Step Potential and Touch Potential in Substation
What Is Step and Touch Potential and Reducing Resistance To Ground?
Creepage Distance for Insulators in Substation
Advantages & Disadvantages of Oil Circuit Breakers
Advantages and Disadvantages of Air Blast Circuit Breakers
Functions of Instrument Transformers (CTs and PTs)
