Reading: Shunt Capacitor Advantages in Power System
Inst Tools > Blog > Power Systems > Shunt Capacitor Advantages in Power System
Last updated: September 20, 2016 2:22 pm
Power Systems
2 Min Read
Normal loads on ac supply system are inductive in nature (eg: motors, power transformers, voltage regulators, induction furnace, choke coils, magnetic systems, discharge tubes etc) Inductive power requires reactive power in addition to active power (active power is required to do the true work). The reactive power increases the load imposed on the system.
When a capacitor is installed across an inductive load (i.e, parallel to the load), the load starts receiving reactive power from the capacitor and thus capacitor power neutralizes the reactive power requirement of the inductive load. Consequently the supply system is relieved from producing reactive power to the load and it can able to deliver greater active power. When the power factorimproves towards unity, the transmission losses decreases due to reduced current and the system voltage improves. A healthy supply enables machines and protection equipment to give optimum output in terms of performance and operational life span.
Some of the advantages due to installing shunt capacitors in the power system are explained below
  • For a particular active power (kW) the resultant demand (kVA) is subsequently reduced. So additional machines can be installed for given sanction of kVA load
  • Since voltage drop is minimized, motor torque capability ( Torque α Voltage2 ) improves, so starting time and the motor heating gets considerably reduced. Motor current requirement for the same output is lesser
  • Because of  less heating, the ageing of the insulation becomes slow and thus the life of the machine and the cables increases
  • Switchgear wear and tear is minimized because of lesser arcing energy dissipation (i.e, lesser acing time) at higher power factor
  • Reduced losses in the feeders lead to lesser voltage drop, hence greater voltage regulation
Rotor Angle Stability of Synchronous Generators in Power System
Shunt Vs Series Capacitors Advantages
Underground Cable Fault Identification Methods
Reactive Power Sources and Sinks in Power System
Silicon Carbide Lightning Arresters Working Principle
Why Symmetrical Components Used for Unbalanced faults in Power System
Neutral Grounding Practice in Power System
Ungrounded or Isolated Neutral System Disadvantages
Advantages & Disadvantages of AC power and DC power
Auto Recloser Circuit Breaker in Power System
harmonics-disadvantages-in-power-system
Harmonics Disadvantages in Power System
why-reactive-power-is-generated-at-load
Why Reactive Power is Generated at Load
harmonics-effect-on-induction-motor
Harmonics effect on Induction Motor
current-limiting-reactors-and-short-circuit-currents
Current Limiting Reactors and Short Circuit Currents
Power System Protection Quiz
Electrical Power System Protection Quiz
Why Grounding
Generating Station Grounding Principles
Voltage Variations Effects on Power Plant Equipment
harmonics-effect-on-transformer
Harmonics effect on Transformer
PLC Program for Daily Production Record
Ground Rod
What is a Ground Rod?
Liapunov’s Stability Analysis
Direct Method & Constructing of Liapunov for the Linear & Non-Linear System
Power Tool Maintenance
Power Tool Maintenance – When And How To Replace Carbon Brushes
Valves Pressure Loss - Questions and Answers
Valves Pressure Loss – Questions and Answers
GSM Based Projects
GSM Based Projects – Ideas and Topics
electrical-drives-questions-answers
Electrical Drives Questions & Answers
OpenPLC - PLC Training for Students - Free Tutorials & Courses
