Hello Dear,
I am receiving many queries, requests for articles, doubts etc… I am doing my best within the free time. Sometimes its been very hard to support everyone requests. If any one have some free time and interest to contribute, then please find the below requests, take any one & write an knowledgeable article, Mail to InstrumentationTools@gmail.com
Really appreciate for any contributions.
Author credits will be mentioned at the bottom of the article.
Note : Word Document preferred, Use Clear images either embed in word doc or attach separately.
Support Instrumentation ToolsPending Requests :
1. Reversing Control valve actuator “fail to” mode: I want to reverse the “fail safe” mode of a Masonelian (MIL) make control valve   from “fail to  open” to “fail safe close ” and vice versa. Received Help from ” Babak Omidi “
2. We have a turbine flow meter, gas chromotograph & flow computer installed at our site, similar units installed at GAIL terminal also. How metering can be done with these two setups. GAIL (gas distribution company) people used to do turbine flow meter calibration, is it possible to do calibration on site for a turbine type flow meter. Please let me know the procedure if any.  Article submitted by Arunbalaji Baskar
3. why we measure coefficient of control valve  Article submitted by R. Jagan Mohan Rao
4. cdm probes  using in gas turbine model ge 9fa, principle, theory, working etc
5. Accelrometers which is used for vibration measurement in pumps and compressor are malfunctioning. While we use waky taky nearby the accelrometers i was reaching the maximum value of vibration from 4~20ma.
6. how to calibrate a weigh feeders, principle/working of weigh feeders
7. Kiln inlet analyser  (used to measure O2,CO,NO )
8. Kiln output –  (used to measure H2O ,NO,NO2,SO2,CO and O2)
9. SWAS analyzer and CEMS for chimney (continues emission monitoring system)
10. How will a field Junction box of conventional 4-20 mA connection look different from that of Foundation Field bus JB. Pl give good images. Received Help from ” Nilima singh “
11. Difference between Set Priority SR Flip Flop and Reset Priority RS Flip Flop Article submitted by R. Jagan Mohan Rao
12.  in a closed loop cascade control how to operate a control valve by forcing transmitter signal using FF in 475 field communicator
13. may i know the steps to loop check a Foundation fieldbus transmitter and control valve in a 475 or 375 communicator
14. what is IS CABLE AND NON IS CABLE ? Received Help from ” Nilima singh “
15. Can You give information about steam turbine HP valve and LP valve(Extraction) and ESV valve. Woodward’s governor 505E types and details.
16. how to use and read chart circular chart recorder for flow measurements
17. I request you to present a topic on DCS that covers Serial Communication with other systems and how it is done at the card level. How this is presented in the HMI/ or Workstation. What is a control network and data highway? What are the different levels in DCS? What are the different types of signals encountered in different levels? What is the difference between OPC connectivity? Where do you need a server? a gateway, router in DCS?
18. A waste heat recovery boiler main steam line flow transmitter (range 0-10000mmWC).at temp:-515 °c. How convert mmWC into tone per hour mass flow rate unit ? Can I use same transmitter for level measurement ?
19. how can we use a DP flow transmitter for level measurement, plz explain in detail. I am fresher, so plz tell me point to point.  Recieved help from ” Ludwich Pretorius ”
20. Foundation Fieldbus Pressure Transmitter & temperature Transmitter calibration Procedure using HART Communicator. Pl share.
21.How does a redundant controller comes in line when the main controller fails??
22.How to determine the upstream and downstream pressure in a control valve !!!  Either in full close or full open in valve position
23. Basic concepts of PLC wiring. How-to, Do’s and Don’t etc.
24.  Barton Make Circular Chart Recorder. Can you help me out with the calibration procedures. Article submitted by R. Jagan Mohan Rao
25. I have using Honeywell DP Smart tx ST700 one side remote seal DC200 fill fluid and other side tubing. The vessel always in vaccume of around -2500mmwc. The hight of taping is 1940 mm. and sg of process fluid 1.02. I use wet leg method and refrence fluid is water. My problem is it shows wrong reading. when vessel is empty it increases. I try my best..but its not working..Please give me some suggestion and LRV URV value. Currently LRV = -1940 and URV = 38.8
26. JT Valve working principle (oil & Gas)  Article submitted by R. Jagan Mohan Rao
27. i am not able to find any technical write up regarding hydraulic  pressure required for  own hole or Subsurface safety valve . What is impact head pressure ,Well shut in pressure and safety margins are required to be considered during hydraulic pressure sizing criteria for down hole or Subsurface safety valve . If possible please advise the recommended standards where we can get  required guidelines.
28. how to review&verify hookup diagram for instrument erection
29. I want to know about the accepted % error and tolerance for Gauges and Transmitters (Pressure and Differential Pressure Transmitter). If possible please provide me with the reference.
30.  How do we get value 1.157 (Conversion Factor) in formula Cv=1.157Kv Or Cv= 1.157×Q×sqrt(G/delta P). If any idea plz explain. I refer some books bt I don’t get any idea. Article submitted by R. Jagan Mohan Rao
31. Difference between Fieldbus, Profibus and HART Protocols
32. Please explain topics in Building Automation System, topics are  1) bacnet 2) the basics of BAS(Building Automation System) 2.1 Fire alarm system 2.2 security system 2.3 energy efficient system 2.4 controllers use to do BMS 2.5 hvac 3) communication & protocols used 4) Interview question on BMS 5) Some animation if possible
33. glass detector sensor
34. SIS VALVES,
35. F&G oxygen transmitter, Methane transmitter
36. multistage control process vs case control
37. how to create a instrumentation loop drawing, say for  instrument air vessel
38. Multivariable transmitters
39. what is thermowell  and HOW TO DECIDE PROBE LENGTH FOR THERMOWELL
40. what is key phasor on turbine and howdoes it work
41.  would like to know more about Volume Tank requirements as below,
a. Used in control valve application.
b. Accessories for Volume tank
c. Working (Animation required)
d. Selection Criteria
42. For control valve seat leakage, now as per new standard ANSI-FCI-70-2013, Class V valves can be tested through air also. If possible, please can you share this standard also on this website. Thanks,
43. instrument fitter interview questions
44. details of hydraulic sov and possibly to control the valve with hydraulic sov with hydraulic actuator
45. does different types of flow measurements (venturi, vortex, RO etc) impact the performance of the antisurge control loop?
46. How to make PI tuning for Anti surge controller?
or Check InstrumentationForum.com, Answer the user questions.
Gain Your Knowledge Every Day.
Share via
Send this to a friend
