Communication between Wincc and Tia Portal
This article is about communication between WinCC and TIA portal using simple programming examples and screenshots.
Step 1:
Open TIA PORTAL. Create a new project. Configure the devices and open programming environment.
Step 2:
The same way, create a new project in HMI. I already created an article on it. Read the article before proceed here.
Step 3:
From the above two steps, we created new projects in Tia Portal and WinCC.
After creating new projects, let’s move to establish communication between them.
As shown in the below window click on option “HMI” and expand it. Double click on “device configuration”.
Step 4:
Click on “network view”. Here, you can see PLC is added to the network as we already have configured while creating a new project.
Make sure that you select CPU and HMI have which contains the same port for communication. Here, I have select HMI and CPU which have the same PROFINET port in common.
Network View in Tia Portal
Step 5:
Now as shown in the below window select Profinet port in green color and drag that to the same port of HMI. Doing that will create a network.
PLC and HMI Communicate
Step 6:
Now to check communication established properly select any one HMI or PLC and do right click on it to open the selection menu as shown in the below window.
Click on “compile” and select “hardware rebuild all”.
Compile Project in Tia Portal
Step 7:
You are done with communication. To check IP address select “HMI” as shown in the below window. Click on “device view”.
Tia Portal Device View
Step 8:
Following window will pop-up. Click on green color Profinet port. In the “general” section, select the “Profinet interface” where you can find an IP address and you can make changes with your application.
Tia Portal IP Protocol
Step 9:
Do follow the same procedure for CPU to check an IP address.
Author: Suhel Patel
