PLC Timers Program
Write a PLC Timers Program for the following plc example.
Table of Contents
PLC Timers
Construct a PLC timing circuit that will output (using output O:2/0) a 0.5 second pulse every two seconds (i.e. on for 0.5s then off for 2s).
If a switch (using I:1/0) is closed and a 1 second pulse every two seconds if the switch is open.
Ladder Logic
PLC Timers Program
You can share a detailed explanation of the above PLC ladder logic in the comments section.
Author: Dr. D. J. Jackson
2 thoughts on “PLC Timers Program”
