Schematic Diagram of an open tank DP level transmitter installation
Formulas:
Min range = SG x h + P0
Max range = SG x h + P 0
Example:
If an X height is 10 meters and there is fluid in the tank which has a density of 0.85 g / cm3 what the calibration range of the transmitter?
SG = 0.85
= 0.85 x 0 m + 0
= 0 mH 2 O
= 0.85 x 10 m + 0
= 8.5 mH 2 O
The transmitter calibration Range = 0 to 8.5 mH 2 O
4 thoughts on “Open Tank DP Level Transmitter Calibration”
    • Hi,
      SG is the specific gravity of the liquid inside the tank, P0 is the pressure of vapor inside the Tank , if the Tank is open to atmosphere than P0 = 1 bara = 0 barg. In the case above you can see that he is using P0 = 0 barg in the calculation because it is said that in this situation it is an open tank.
