Business Operations
Computers & Electronics
Engineering & Technology
Generate Pulse Timer in PLC - TP Timer Instruction - Siemens Tia
23K views
Aug 30, 2022
In this video, you will learn the operation and usage of generate pulse timer in PLC programming.
This is also called a TP timer.
You can use the "Generate pulse" instruction to set the Q output for a programmed duration.
The programmed time PT begins when the instruction starts. Output Q is set for the duration PT, regardless of the subsequent course of the input signal.
While the time PT is running, the detection of a new positive signal edge at the IN input has no influence on the signal state at the Q output.
## Free PLC and SCADA Training Courses ##
1. Free Siemens PLC Training Course
https://instrumentationtools.com/siemens-plc-training/
2. Free Allen Bradley PLC Ladder Logic Training Course
https://instrumentationtools.com/free-allen-bradley-plc-ladder-logic-training-course/
3. Free InTouch SCADA Tutorial Course for Beginners
https://instrumentationtools.com/intouch-scada-training-course/
4. Free WinCC SCADA Training Course
https://instrumentationtools.com/scada-training-course/
#plc #PulseTimer #TPtimer
Show More
Show LessComments
loading text loading
loading text
loading text
loading text
loading text
