EtherCAT based Motion Controller with PLC and Servo Drives
2K views
Oct 28, 2022
In this PLC project, you will learn the EtherCAT based motion controller with PLC and servo drives.
Correction - At the 7.34 timestamp, We used Ethercat Protocol but we mentioned Modbus. Please consider it Ethercat.
The servo drivers are connected to the PLC in series one by one through the network cable.
The number nearest to the PLC is 0, which is 1, 2,.... 31 in sequence (the numbering method is the same as that of the PLC module)
Then configure each servo in the PLC software, and finally control the servo movement through the program.
*** Contact Details ***
Email
sales@we-con.com.cn
Technical Support
support@we-con.com.cn
#ethercat #servodrive #servomotors #motioncontroller #plc
--------Tags
ethercat,automation,cnc,ethercat master,ethercat slave,industrial ethernet,servo,servo drives,servo motors,motion controller,industrial automation,motion control,industrial automation projects,industrial automation training videos,ethercat motion controller,ethercat tutorial,ethercat servo drive,ethercat cnc controller,ethercat cnc,ethercat slave controller,servo motor,servo motor control,servo motor project,servo drives and motors,plc,control,motor,drive
Show More
Show LessComments
loading text loading
loading text
loading text
loading text
loading text
