Learn Siemens Tia Portal Programming Online - CEIL, FLOOR, TRUNC
In this video, you will learn the ceil, floor, trunc functions in Siemens Tia portal. CEIL: Generate next higher integer from floating-point number. You can use the "Generate next higher integer from floating-point number" instruction to round the value at input IN to the next higher integer. FLOOR: Generate next lower integer from floating-point number You can use the "Generate next lower integer from floating-point number" instruction to round the value at input IN to the next lower integer. TRUNC: Truncate numerical value You can use the "Truncate numerical value" instruction to form an integer from the value at the IN input. ## Free PLC and SCADA Training Courses ## 1. Free Siemens PLC Training Course https://instrumentationtools.com/siemens-plc-training/ 2. Free Allen Bradley PLC Ladder Logic Training Course
