PLC Sequence Control of Pneumatic Cylinders with Solenoid Valves
4K views
Aug 30, 2022
In this video, you will learn the PLC programming for sequence control of pneumatic cylinders with solenoid valves. Develop a PLC program that will operate the cylinders in the desired sequence. The time between each step is to be 3 seconds. The sequence of operations will be as follows: • All cylinders to retract. • Cylinder 1 advance. • Cylinder 1 retract and cylinder 3 advance. • Cylinder 2 advance and cylinder 5 advance. • Cylinder 4 advance and cylinder 2 retract. • Cylinder 3 retract and cylinder 5 retract. • Cylinder 6 advance and cylinder 4 retract. • Cylinder 6 retract. • Sequence to repeat ## Learn PLC Programming using Examples ##
#Factory Automation
#Fluid Handling
#Manufacturing
