PLC Programming Instructions
22K views
Aug 31, 2022
A Ladder Diagram is one of the simplest methods used to program a PLC.
It is a graphical programming language evolved from electrical relay circuits. Each program statement is represented with a line, called the rung, that has all relevant inputs to the left and the output to the right.
The output device of a rung is energized if electric power can conceptually flow from the left side of the rung to the right side. Input devices are assumed to block the flow of power if they are not activated.
During the execution of a ladder diagram, the PLC reads the states of all inputs, then determines the states of all outputs starting from the rung at the top side, going down to the last rung, and finally updates the state of the output devices.
PLC Training Material:-
https://instrumentationtools.com/learn-programmable-logic-controller-plc/
Show More
Show LessComments
loading text loading
loading text
loading text
loading text
loading text
