Communication between InTouch Scada and Allen Bradley PLC
This article is about communication between InTouch SCADA and Allen Bradley PLC with a ladder logic example with screenshots.
Do follow the below steps for establishing the communication process.
Step 1:
Open RSlogix software along with RSlinx and emulator.
Step 2:
Create a new project in RSlogix and established communication with an emulator.
Step 3:
Open InTouch SCADA software.
Step 4:
As you can see in the below window of RSlogix I have created a small example with one input and output.
In branch, I have use memory bit which we will use in SCADA to give a command.
RSLogix Micro Starter Lite
Step 5:
Now, let open RSlinx. Click on option “DDE/OPC” and choose “topic configuration”.
RSLinx Configuration
Step 6:
Following window will pop-up. Choose “New” to proceed.
DDE OPC Configuration
Step 7:
Create a new topic as I have created communication and choose communication protocol. Click “apply” then “done” to proceed.
MicroLogix 1000
Step 8:
Now open InTouch SCADA. Create a new project.
As we have used one input and output we have to create one input button and output button as shown in the below window.
InTouch Window Maker
Step 9:
Hit double click on a button will open up the following window. Choose “Discrete” will open up a new window.
Discrete Inputs in InTouch
Step 10:
Give a name to button and hit “ok” to proceed.
Tagname in InTouch
Step 11:
Choose I/O Discrete in the “Type” option. Then click on “access name”.
Write a bit address in “item” for input which we have used in the programming software (check step no. 4).
InTouch Access Name
Step 12:
Clicking on Access name will open another window. Click on “add” as shown in the below window.
InTouch Tagname Dictionary
Step 13:
This is a very important step to establish communication.
Access: Give any name
Application name: RSlogix
Topic name: communication (the same name we have used in step no. 7)
Choose “DDE” as a communication protocol and hit “ok” to proceed.
Add Access Name in Scada
Step 14:
After configuration hit “save” and close the pop-up.
Save InTouch Scada
Step 15:
For output, we have select “fill color” property and choose “Discrete”.
Fill Color InTouch Scada
Step 16:
Do follow the same procedure for output as shown in the below window.
Type of IO in InTouch Scada
Step 17:
Communication has established. Test the logic. Keep a window in “runtime” and put CPU in “run” mode.
As you can see in the below window output gets energized if I give the command from SCADA.
Communication between Intouch Scada and Allen Bradley PLC
Author: Suhel Patel
3 thoughts on “Communication between InTouch Scada and Allen Bradley PLC”
