How Diaphragm Valves Work ?
Diaphragm valves use a flexible sheet pressed close to the edge of a solid dam to narrow the flow path for fluid.
Their operation is not unlike controlling the flow of water through a flexible hose by pinching the hose. These valves are well suited for flows containing solid particulate matter such as slurries, although precise throttling may be difficult to achieve due to the elasticity of the diaphragm.
Diaphragm valve Operation
Diaphragm valves (or membrane valves) consists of a valve body with two or more ports, a diaphragm, and a “weir or saddle” or seat upon which the diaphragm closes the valve. The valve body may be constructed from plastic, metal, wood or other materials depending on the intended use.
There are two main categories of diaphragm valves: one type seals over a “weir” (saddle) and the other (sometimes called a “full bore or straight-way” valve) seals over a seat. The weir or saddle type is the most common in process applications and the seat-type is more commonly used in slurry applications to reduce blocking issues but exists also as a process valve.
While diaphragm valves usually come in two-port forms (2/2-way diaphragm valve), they can also come with three ports (3/2-way diaphragm valves also called T-valves) and more (so called block-valves). When more than three ports are included, they generally require more than one diaphragm seat; however, special dual actuators can handle more ports with one membrane.
The photograph shows a diaphragm valve actuated by an electric motor, used to control the flow of treated sewage:
The following photograph shows a hand-actuated diaphragm valve, the external shape of the valve body revealing the “dam” structure against which the flexible diaphragm is pressed to create a leak-tight seal when shut:
Some diaphragm valves are pneumatically actuated, using the force of compressed air on one side of the diaphragm to press it against the dam (on the other side) to shut off flow.
This next example is of a small air-actuated diaphragm valve, controlling the flow of water through a 1-inch pipe:
The actuating air for this particular diaphragm valve comes through an electric solenoid valve. The solenoid valve in this photograph has a brass body and a green-painted solenoid coil.
Advantages of Diaphragm Valves
  • Diaphragm valves can also be used for throttling service.
  • Its throttling characteristics are essentially those of a quick opening valve because of the large shutoff area along the seat.
  • A weir-type diaphragm valve is available to control small flows.
  • Diaphragm valves are particularly suited for the handling of corrosive fluids, fibrous slurries, radioactive fluids, or other fluids that must remain free from contamination.
  • The operating mechanism of a diaphragm valve is not exposed to the media within the pipeline. Sticky or viscous fluids cannot get into the bonnet to interfere with the operating mechanism.
  • Many fluids that would clog , corrode, or gum up the working parts of most other types of valves will pass through a diaphragm valve without causing problems. Conversely, lubricants used for the operating mechanism cannot be allowed to contaminate the fluid being handled.
  • There are no packing glands to maintain and no possibility of stem leakage in valves.
Disadvantages of Diaphragm Valves
  • Valve transition has sets, preventing the pipeline from complete discharge.
  • The operation temperature and pressure have limits depending on the diaphragm material. Typically, they are used under 200 psi (14bar) pressure and 204ºC temperature limits.
  • The hydrostatic pressure that can be applied to the diaphragm is limited.
  • Dimensions of diaphragm valves are limited. They are produced in DN15-DN300 dimensions.
Articles You May Like :
Solenoid Valve’s Energized
Breather Valve Principle
Tilting Disk Check Valve
Control Valve Installation
List of Valve Standards
